油田热采锅炉干度测控技术
2012-06-07 20:0112340
Thermal recovery boiler operation dryness is an important parameter,
 which affects the accuracy of thermal recovery boiler operation safety
 and the effect of heating oil. In the water / steam two-phase flow
 dynamic monitoring techniques based on the developed dryness
 microcomputer measurement and control technology, is to use
 differential throttling device measuring degree of wet and
dry steam flow, and other parameters, with the temperature
 and pressure sensors will be able to automatic Detection of
 thermal recovery boiler operation, while the boiler through
the feedback control signal to the amount of water and wind
to achieve the safe operation of thermal recovery boiler
 automatically.
Key words: dry degree; thermal recovery boiler; thermal oil
